Home > Technical (L322) > Front main blower GAP code B12FE-13 (28) Fan |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1367 |
Circuit open indicates a break in the circuit, which could be anywhere. Usually brushes give good warning, and on the L322, the fan bearings will have gone before the brushes do, so you'd most likely have had audible symptoms if it were the cabin fan.
23rd Apr 2024 10:18pm |
DEEBEE(060) Member Since: 18 Jun 2022 Location: Georgia Posts: 42 |
Thanks Gary,
23rd Apr 2024 10:46pm |
So replaced the resistor today and still no fan. Again all lights on dash lit and change as dial turned. Resistor getting hot, both the old one and new. Unless I get another suggestion, next to change is the fan. Any other thoughts appreciated |
26th Apr 2024 9:14pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Gary did a cracking blower replacement guide
27th Apr 2024 8:30am |
Thanks, just saw that and will use |
27th Apr 2024 9:03am |
Will I have any issues testing the new fan once installed with the airbags on the dash disconnected, ie. before full reassembly? My thoughts are no as long as I disconnect battery before reassembly. Anyone else's thoughts? |
27th Apr 2024 8:24pm |
It might trigger an airbag fault code and warning on the dash, but as you have an IID tool, you can easily clear that. 2015 Range Rover Autobiography 4.4 SDV8 |
27th Apr 2024 8:40pm |
Thanks |
27th Apr 2024 8:59pm |
So opened up the cabin filter air box today and was expecting to find access to fan to apply WD40. What I found was 2 vents obscured by “?flaps” that did not open when adjusting air inside with engine running or use of recycle switch. I now have a fan to fit. So far all fuses checked, resistor changed. Power to fuse 21 at rear. A/c is working as get cold air through when car moving. Pics enclosed of area with air box removed |
12th May 2024 12:32am |
