Home > Technical (L322) > Front main blower GAP code B12FE-13 (28) Fan
DEEBEE(060)
United States 2012 Range Rover HSE 5.0 V8 Orkney Grey
2012 RR full fat HSE 5.0 V8 Non SC
So before I start blowing money on resistors and fans and even relays, has anyone seen and fixed this error. Just driven back from Florida with no cold air. All dash lights work, Car had sat at cruise terminal for a week and when we jumped back in no front blower. Fuse F62 all OK. No drain on battery after a week. Seemed to get some very low intermittent air, occassionally
First thoughts after fuses was the resistor, any thoughts? Others have changed this and still have the problem.
I am not sure which the relay is, or if there is one for the front!!! anybody let me know?
Any ideas on P010B-00 (ECool, Occasionally shows up
Any help at all appreciated
Post #691066 22nd Apr 2024 1:28am
garyRR
Circuit open indicates a break in the circuit, which could be anywhere. Usually brushes give good warning, and on the L322, the fan bearings will have gone before the brushes do, so you'd most likely have had audible symptoms if it were the cabin fan.
Setting the fan on maximum (also try demist button and Max AC), does the fan run? (If so, this would indicate a resistor issue).
I'm not sure there is a fan relay - I think it's controlled via the resistor.
Alternatively, the battery may just have gone a bit flat, especially if aircraft overhead set the alarm off. A charge up and maybe disconnect and reconnect may be worth a try. 2015 Range Rover Autobiography 4.4 SDV8
Post #691175 23rd Apr 2024 10:18pm
DEEBEE(060)
Thanks Gary,
not the battery as drove 650 miles and still the same. No screeching, smell etc like when a motor starts to go out.
Felt like it tried to come on at a very slow speed at times but not enough to cool. Will try the resistor as I have already ordered it. There is no sign of a relay, except for the back which is fine and blowing cold.
Will let you know how I get on.
Post #691180 23rd Apr 2024 10:46pm
DEEBEE(060)
So replaced the resistor today and still no fan. Again all lights on dash lit and change as dial turned. Resistor getting hot, both the old one and new. Unless I get another suggestion, next to change is the fan. Any other thoughts appreciated
Post #691372 26th Apr 2024 9:14pm
DrRob
Gary did a cracking blower replacement guide Bow down
https://www.fullfatrr.com/forum/topic67642.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #691389 27th Apr 2024 8:30am
DEEBEE(060)
Thanks, just saw that and will use
Post #691393 27th Apr 2024 9:03am
DEEBEE(060)
Will I have any issues testing the new fan once installed with the airbags on the dash disconnected, ie. before full reassembly? My thoughts are no as long as I disconnect battery before reassembly. Anyone else's thoughts?
Post #691433 27th Apr 2024 8:24pm
garyRR
It might trigger an airbag fault code and warning on the dash, but as you have an IID tool, you can easily clear that. 2015 Range Rover Autobiography 4.4 SDV8
Post #691435 27th Apr 2024 8:40pm
DEEBEE(060)
Thanks
Post #691436 27th Apr 2024 8:59pm
DEEBEE(060)
So opened up the cabin filter air box today and was expecting to find access to fan to apply WD40. What I found was 2 vents obscured by “?flaps” that did not open when adjusting air inside with engine running or use of recycle switch. I now have a fan to fit. So far all fuses checked, resistor changed. Power to fuse 21 at rear. A/c is working as get cold air through when car moving. Pics enclosed of area with air box removed
Post #692415 12th May 2024 12:32am
