Home > Maintenance & Mods (L405) > Good 'ol oil cooler leak - Question! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3066 |
Having had mine (2011 L322) done by a very experienced, highly reputable LR specialist, his advice was to change the whole cooler as they can become warped (they are in 2 parts, upper and lower) where they join and will continue to leak if this is the case and only seals are replaced.
19th Apr 2024 2:29pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 260 |
I have just done mine. I was given the same advice, replace the cooler, so that’s what i did. I believe the old one was the original so 10 years and 80k miles.
19th Apr 2024 3:37pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
Yes, as above, had mine changed in 2016. Mine had warped so needed the whole unit replacing. The coolant will need flushing out a few times if oil has got in to there.
19th Apr 2024 3:38pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 124 |
I agree it does look like an oil cooler replacement is required to exclude issues with warping etc, although I have no issue paying to get it done I do have warranty cover tat really should cover most of it but warranty companies being what they are, WarrantyWise specifically, they can get quite evasive where oil leaks are concerned and will most likely not want to cover the oil cooler, even though my policy says it is covered? _______________________________________________
19th Apr 2024 4:09pm |
Make sure you check for oil in your coolant. This will require a flush through as Richie said and poss a new coolant bottle (as in my case).
19th Apr 2024 4:16pm |
Well much to my surprise my Warranty company have stepped and will cover the cost of about 90% of the cost to replace the oil cooler, cant really complain at that I suppose. _______________________________________________
23rd Apr 2024 12:39pm |
