Home > Maintenance & Mods (L405) > Good 'ol oil cooler leak - Question!
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Addressing the, currently, minor oil cooler leak is fast approaching as I tick things off of my 'ToDo' list.
Now my vehicle is just coming up to 58k miles.
What I am asking is peoples opinion of just how long this sort of repair would be expected to last before needing to be done again?
I have one garage telling me that just a seal kit is needed and another telling me that it is best to replace the complete oil cooler. I prefer replacing the oil cooler myself but are your thoughts?
What else should I be asking to get replaced to make this repair last the longest without having to revisit the area again anytime soon? I seem to remember reading in a post somewhere that there are a couple of 'O' rings on some pipe or other?
Thoughts and suggestions please Thumbs Up _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #690909 19th Apr 2024 2:10pm
Dolphinboy
Having had mine (2011 L322) done by a very experienced, highly reputable LR specialist, his advice was to change the whole cooler as they can become warped (they are in 2 parts, upper and lower) where they join and will continue to leak if this is the case and only seals are replaced.
You have to remove the cooler anyhow to clean and change the seals and gasket, so for a couple hundred quid more (£360 inc vat for LR part) and 3 hrs labour, have a new OEM cooler installed and have piece of mind.
Post #690911 19th Apr 2024 2:29pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I have just done mine. I was given the same advice, replace the cooler, so that’s what i did. I believe the old one was the original so 10 years and 80k miles.
I would change all the seals and possibly some of the pipes in the area. I didn’t and still have a slight water leak that I’m chasing.
There’s also a plastic fitting above the thermostat housing that is known to become brittle and break.
Good luck 👍
Post #690914 19th Apr 2024 3:37pm
mjdronfield
Yes, as above, had mine changed in 2016. Mine had warped so needed the whole unit replacing. The coolant will need flushing out a few times if oil has got in to there.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #690915 19th Apr 2024 3:38pm
ReggieMac
I agree it does look like an oil cooler replacement is required to exclude issues with warping etc, although I have no issue paying to get it done I do have warranty cover tat really should cover most of it but warranty companies being what they are, WarrantyWise specifically, they can get quite evasive where oil leaks are concerned and will most likely not want to cover the oil cooler, even though my policy says it is covered? _______________________________________________
Post #690916 19th Apr 2024 4:09pm
Dolphinboy
Make sure you check for oil in your coolant. This will require a flush through as Richie said and poss a new coolant bottle (as in my case).
Any further coolant leak may be the EGR Cooler (v expensive to fix!! c. £1100)
Post #690917 19th Apr 2024 4:16pm
ReggieMac
Well much to my surprise my Warranty company have stepped and will cover the cost of about 90% of the cost to replace the oil cooler, cant really complain at that I suppose. Thumbs Up _______________________________________________
Post #691143 23rd Apr 2024 12:39pm
Ukandrewf
who was your warranty company?
Warranty wise have agreed to pay for the oil cooler but don't want to pay for new gaskets or seals!!! As a result of ignoring everything else they only want to pay 2.2 hours about for the cooler repl;acement itself not the cost of labour to get to it and replace gaskets etc.
I found a case from the motor obudman that says if the main item is covered all the component parts (like gaskets etc ) should be covered unless specifically excluded which they're not on the policy.
Andrew --
On my third Full Fat RR
Post #708880 11th Jan 2025 7:47pm
ReggieMac
It was WarrantyWise and I have the 06/60 plan. They did not pay for the engine oil is all. _______________________________________________
Post #708959 12th Jan 2025 6:47pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
I replaced the gaskets only 5 years ago. No leaks yet. I think I caught it early enough. I assume not much if any difference in design between the TDV8 in the ‘322 vs the SDV8 in the 405. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #708960 12th Jan 2025 7:44pm
Crasher242
Oil in the coolant? Funny you should say that...
I was topping up my coolant at the weekend as I got the low coolant warning and to my untrained and somewhat tired eyes, it looked like there was traces of oil in the coolant expansion chamber when I topped up.
I know I have both a non-excessive oil leak and a non-excessing coolant leak Rolling Eyes
So what is the story with oil in the coolant system then? I am presuming I need to go and pluck some more cash off the money tree in the garden to sort these things out Big Cry Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #709104 14th Jan 2025 3:14pm
The Choad
Just doing mine at the moment, hence my Q's on another post!! Have opted just to change the seals, old ones were absolutely rock hard and flat as a pancake. Hoping new seals will solve the problem.
The seals act between the joint of the oil filter cooler adapter and the EGR cooler body on the bottom face, and the oil cooler and the adapter on the top face. There are coolant pathways and oil pathways running side by side on both sides, and the seal also keeps these pathways separate, in addition to keeping everything inside. When the seal fails not only can stuff leak out, it can also move from one to the other, but generally oil to water given the pressure difference.
Post #709502 17th Jan 2025 9:55pm
