![]() | Home > Maintenance & Mods (L405) > Good 'ol oil cooler leak - Question! |
Having had mine (2011 L322) done by a very experienced, highly reputable LR specialist, his advice was to change the whole cooler as they can become warped (they are in 2 parts, upper and lower) where they join and will continue to leak if this is the case and only seals are replaced.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 358 ![]() ![]() ![]() |
I have just done mine. I was given the same advice, replace the cooler, so that’s what i did. I believe the old one was the original so 10 years and 80k miles.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7853 ![]() ![]() ![]() |
Yes, as above, had mine changed in 2016. Mine had warped so needed the whole unit replacing. The coolant will need flushing out a few times if oil has got in to there.
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 214 ![]() ![]() ![]() |
I agree it does look like an oil cooler replacement is required to exclude issues with warping etc, although I have no issue paying to get it done I do have warranty cover tat really should cover most of it but warranty companies being what they are, WarrantyWise specifically, they can get quite evasive where oil leaks are concerned and will most likely not want to cover the oil cooler, even though my policy says it is covered? _______________________________________________
Make sure you check for oil in your coolant. This will require a flush through as Richie said and poss a new coolant bottle (as in my case).
Well much to my surprise my Warranty company have stepped and will cover the cost of about 90% of the cost to replace the oil cooler, cant really complain at that I suppose. |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 245 ![]() ![]() ![]() |
who was your warranty company?
It was WarrantyWise and I have the 06/60 plan. They did not pay for the engine oil is all. _______________________________________________
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 409 ![]() ![]() ![]() |
I replaced the gaskets only 5 years ago. No leaks yet. I think I caught it early enough. I assume not much if any difference in design between the TDV8 in the ‘322 vs the SDV8 in the 405. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 136 ![]() ![]() ![]() |
Oil in the coolant? Funny you should say that... I was topping up my coolant at the weekend as I got the low coolant warning and to my untrained and somewhat tired eyes, it looked like there was traces of oil in the coolant expansion chamber when I topped up. I know I have both a non-excessive oil leak and a non-excessing coolant leak ![]() So what is the story with oil in the coolant system then? I am presuming I need to go and pluck some more cash off the money tree in the garden to sort these things out ![]() Vogue SE 4.4 SDV8 Previous highlights Many Mini's! Audi S8 Audi A6 Avant (the petrol guzzling Bi-turbo) Subaru H6 3.0 Estate Peugeot 406 Coupe V6 Audi 80 Quattro Sport |
The Choad Member Since: 28 Nov 2024 Location: South East Posts: 3 ![]() ![]() |
Just doing mine at the moment, hence my Q's on another post!! Have opted just to change the seals, old ones were absolutely rock hard and flat as a pancake. Hoping new seals will solve the problem.
