![]() | Home > Wheels & Tyres > New tyre time - Verde or Zero PNCS? |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 98 ![]() ![]() ![]() |
Pirelli now have the Scorpion MS, which claims to be an upgrade to both the Scorpion Verde All Season and the Scorpion Zero All Season.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8725 ![]() ![]() ![]() |
The other Pirelli to look at is the Scorpion SF2.
woodyrvf750 Member Since: 10 Jul 2023 Location: Stratford Upon Avon Posts: 22 ![]() ![]() |
I’ve just fitted the SF2 on my 4.4 TDV8 Westminster and the wet performance is as a tyre should be. Unlike the All Season PNCS (AS-PNCS) which I found comically dangerous in the wet and would lift off the road at the slightest whiff of standing water.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 897 ![]() ![]() ![]() |
I have 255 50 R20 Scorpion Zero AS ( All Season ) PCNS tyres on the front, and after 5000 miles they are absolutely fine in heavy rain bombing down motorways, no hint of aquaplaning or lift, can't imagine Pirelli would manufacture an AS tyre that also qualifies for B marking and not meet those specs !
There's a difference between wet braking performance and aquaplane resistance. Generaly you can avoid aquaplaning by driving according to the conditions of the road. I've driven in all sorts of conditions and roads in the last 3 years / 45k miles on Verde's and never had an aquaplaning incident but then maybe that's reflected in the way I drive and why I easily got 30k miles out of a set of tyres and not 9k miles...... 2012 TDV8 Vogue (L322) |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Just a thought re aquaplaning and tyre pressure
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1635 ![]() ![]() ![]() |
[quote="pcourtney"]
maybe woody's trye pressures were a little low, most of the time mine are Front 2.3 Rear 2.5 bar, I check them every week, only because I have a DeWalt tyre inflator, and it only takes a few minutes to top them up |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
I'm not joining the tyre debate, but I do agree with Gremlin if you are really worried about the absolute performance of a tyre then and you have a RR then you have the wrong car.
