Home > Maintenance & Mods (L405) > Sdv8 coolant bleeding procedure |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Workshop Manual is downloadable from the WIKI, link top right of page under fullfatrr.com Pete
4th Apr 2024 6:58pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
You won't need to bleed it after fitting an oil cooler sir... Just top up the reservoir...
5th Apr 2024 1:12am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 95 |
The easiest way to hopefully avoid bleeding is to vacuum fill the coolant.
6th Apr 2024 6:01pm |
