![]() | Home > Maintenance & Mods (L405) > Sdv8 coolant bleeding procedure |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8512 ![]() ![]() ![]() |
Workshop Manual is downloadable from the WIKI, link top right of page under fullfatrr.com Pete
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
You won't need to bleed it after fitting an oil cooler sir... Just top up the reservoir... |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 150 ![]() ![]() ![]() |
The easiest way to hopefully avoid bleeding is to vacuum fill the coolant.
