Home > Maintenance & Mods (L405) > Sdv8 coolant bleeding procedure
Jam2010marie
United Kingdom 2016 Range Rover Vogue SDV8 Firenze Red
Hello, any chance someone could post a link to coolant bleeding procedure for the sdv8, as I can't seem to find it, I'm changing the oil cooler this weekend and I assume there will be a bit of coolant loss, cheers
Post #689919 4th Apr 2024 5:06pm
Workshop Manual is downloadable from the WIKI, link top right of page under fullfatrr.com Pete
Post #689923 4th Apr 2024 5:58pm
You won't need to bleed it after fitting an oil cooler sir... Just top up the reservoir... Thumbs Up
BUT, if ever you do need it, there are two bleed screws. One on top of the header tank and another quite well hidden just in front of the brake fluid reservoir cover. Drivers side scuttle panel area Thumbs Up
Post #689962 5th Apr 2024 12:12am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
The easiest way to hopefully avoid bleeding is to vacuum fill the coolant.
RR in the workshop maintenance suggest refilling twice with clean water to flush the system before adding back in fresh 50% coolant mix, red OAT from memory. They run through the vac fill procedure in the manual.
AliExpress have decent home mechanic vac kits for around £30, though of course you also need a decent CFM air compressor to hand.
Post #690109 6th Apr 2024 5:01pm
