Home > Technical (L322) > ABS and SAS Communication |
Iwheels Member Since: 26 Feb 2024 Location: Alberta Posts: 15 |
Checked continuity of the lime green wire was pretty weak so I opened the connection. This is what I found. Guess I gotta pull the pins and clean it better
2nd Apr 2024 11:15pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
this is exactly what the Stealer/main dealer failed to check and wanted to charge me £1000 for a new ABS sensor on my 4.4 Petrol!! A quick rub down with a toothbrush and a bit of contact spray and it was all fixed forever! |
3rd Apr 2024 1:05pm |
Used some electrical cleaner and there were about eight of the pins that were badly corroded so I spliced them with butt connectors, but this might not be good enough?
3rd Apr 2024 11:22pm |
Found the fault
25th May 2024 3:38pm |
