Home > Technical (L322) > ABS and SAS Communication
Iwheels
Canada
2010 L322 with 5l. I have multiple lights on the dashboard, went to my mechanic who put the gap tool on and other diagnostics and we found that the steering angle sensor doesn’t even exist.
This means possible wire between ABS and SAS could be compromised. Planning on testing continuity this week.
Does anyone have experience with these wires?
Post #689460 30th Mar 2024 10:50pm
Iwheels
Canada
Found the possible problem
Checked continuity of the lime green wire was pretty weak so I opened the connection. This is what I found. Guess I gotta pull the pins and clean it better
Post #689790 3rd Apr 2024 12:15am
Dolphinboy
this is exactly what the Stealer/main dealer failed to check and wanted to charge me £1000 for a new ABS sensor on my 4.4 Petrol!! A quick rub down with a toothbrush and a bit of contact spray and it was all fixed forever! Evil or Very Mad
Post #689809 3rd Apr 2024 2:05pm
Iwheels
Canada
Used some electrical cleaner and there were about eight of the pins that were badly corroded so I spliced them with butt connectors, but this might not be good enough? Rolling Eyes Confused
Still no connection with the steering angle sensor
My shop says this is a problem where the drain from the sunroof collects in the bottom and if not clean the water will build up
Looks like there’s some salt remnants from the winters here.
Post #689854 4th Apr 2024 12:22am
Iwheels
Canada
Found the fault
The power to the SAS was not getting to it. Canbus was good.
It was faulty behind the dash somewhere so we jumped it from before it goes deep behind the dash to the SAS
Put some liquid electrical tape over the butt connecters and any other exposed wires. (Rough I know)
All good
Codes cleared
Very Happy Thumbs Up
Post #693302 25th May 2024 4:38pm
