![]() | Home > Technical (L322) > " RED" Restrictive Performance |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 186 ![]() ![]() ![]() |
Hi JayGee
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2849 ![]() ![]() ![]() |
If the soot load is only 24.5g this will clear without needing a forced regeneration simply by driving it for a long enough and fast enough for a normal regeneration to clear the soot. I think your resticted performance is not DPF related. Do long enough drive to regen the DPF and don't rev above 2500rpm and see if it behaves. 2012 TDV8 Vogue (L322) |
Well that will be a relief and I will find the best flattish route to try that. Your help is greatly appreciated.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 154 ![]() ![]() ![]() |
read pending errors. |
Hi JayGee
Geat you fixed the DPF issue but you may still have another fault that is causing the restricted performance warning. As Jimmie says scan the pending errors ( enable in the advanced section of the fault scan window) and try to see if it happens when you rev past 2500rpm as this is the point were the 2nd turbo is activated and where control valve / solenoid problems can occor on these cars. 2012 TDV8 Vogue (L322) |
OK JayGee, I hear what you say and I will check that out as you recommend. I do know that I should drain the oil from the 2nd turbo which will be due: awkward to get to the drain plug as you know.
No need to drain the oil from the 2nd sump although some like to do it to get the last few drops out. Just reving it above 2500rpm should burn off the oil acumulated in the intake and exhust side ( noything to do with the sump) and then you will be clear of it for a while until it builds up (or not if you regularly go over 2500rpm) 2012 TDV8 Vogue (L322) |
Hi JayGee
I'm just passing on collective knowledge so can't take any unique ownership of the advice. There is another cause of the smoke which is a leaky valve in the oil filter housing that's used to drain the oil off when unscrewing it. Minesmokes a lot less now it's been fixed. Do a search for the problem and solution as it's been covered extensivley. 2012 TDV8 Vogue (L322) |
Will do and I realise that I'm not finished yet as I didn't do the 2500 rpm part for the advanced fault listing. I will get there it's just a matter of time. |
I have been around the block and pushed the 2500 rpm boundary to produce smoke and the red restrictive performance reappeared. The pending issue routine produced the following code and description: P006A 00 (64) Manifold absolute pressure - mass or volume air flow correlation
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 184 ![]() ![]() ![]() |
Might be worth getting a smoke test done to check for intake leaks. |
Download the workshop manual from teh WIKI section and you can cross reference the fault code with the correct procedure and part's that need looking at. 2012 TDV8 Vogue (L322) |
