Home > Wheels & Tyres > Largest possible L405 tyres with smallest possible rims
Flyboy0902
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Hi all,
I have a 2015 SDV8 405, and I’d like to fit the biggest off road tryres I can with the smallest possible diameter wheels…
Could someone advise…
Thanks Thumbs Up
Post #689110 27th Mar 2024 10:58am
PeteT80
The smallest readily available size rims are 20” to fit over the brake calipers. Think there are some 19” that would fit but not too sure on that. I’m running 255/55/20 General Grabber AT3’s.
Post #689114 27th Mar 2024 11:16am
Flyboy0902
Thanks!
Post #689115 27th Mar 2024 11:22am
fisha
255/60/r20 from a new defender fit the L405 ( at least the Pirelli all seasons do) V8 or else ...
Post #689166 27th Mar 2024 8:34pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Hi Fisha, do you have the Defender alloys fitted to your L405? If so, do you have any pics? 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #689189 28th Mar 2024 9:18am
GraemeS
Australia
Quite a few owners have fitted 275/55R20.
Post #689192 28th Mar 2024 9:33am
JayGee
Just a word of caution for big tyres... The other day I had a combined height sensor and airbag fail and the car dropped to it's bump stops. I was able to drive a short distance to a safe pull over but when I was fixing it I noticed a bit of rub on the arches on my slightly oversized 255/55/R20 so I reckon anything bigger may have rendered the car stuck in the road? 2012 TDV8 Vogue (L322)
Post #689196 28th Mar 2024 10:23am
fisha
Some pictures … I actually quite like them. They have a slightly wider offset, which counters the smaller rim size looking lost in the arches. I’ve not noticed rubbing as yet. Makes for a nice smooth ride compared to the 22” rims I have.
 V8 or else ...
Post #689257 28th Mar 2024 6:38pm
Vogue
285/50/20 work well and are probably the largest you can go risk free without rubbing in all modes - plus you can get a spare in the tyre well - any bigger and it’s very unlikely you will 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #690044 6th Apr 2024 8:45am
bdd123
United States 2017 Range Rover Autobiography 5.0 SC V8 Aintree Green
Slightly surprised by this as it is .3 larger diameter and.8" narrower. What is your wheel and wheel offset? Current: 2017 L405 ATB, 2016 LR4 SE
Past: 2001 RRR H&H, 1993 RRC SE, 1989 RRC, 1990 RRC, 1995-97-98 D1
Post #691824 3rd May 2024 2:48pm
TJNZ
New Zealand 2017 Range Rover Autobiography SDV8 Carpathian Grey
I put these on mine after sourcing some rims and they fit well. I have also sourced a 20inch spare rim but have left the 255 55 50 tyre on it as it was very close in diameter and fits in the spare wheel well. I wasnt sure the 285 would fit there in terms of the height and it may protrude to high for the trunk cover. Did yours fit ok?
 2017 L405 AB SDV8
2011 L322 Vogue SE 4.4 TDV8
Post #691879 4th May 2024 11:36am
Vogue
Yes - just - Cooper AT3, 285/50/20, that was on my previous L405 - pre facelift - not tried on the latest one, just left the std spare in as it’s a space saver and there’s a foam infill beneath - I’ve never needed to use a spare on a RR in at least 20 years - think the last time was on a Classic in 1995 - now I’ve just given it the kiss of death and jinxed everything 🙈😂
If it’s any help, I also kept a thick Collins Route planner map in my boot stored on top of the spare and the boot floor still closed ok - if anything I suspect the diameter was the limiting factor before the height / width 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #691929 4th May 2024 11:15pm
TJNZ
Thanks Thumbs Up for this. Admittedley it was a quick look but the stock 275 22's looked almost flush to the top of the trunk floor. I think I'll do similar to you and just leave the 255 55 20 rim and tyre in there as a backup. My OCD will have me respraying the spare bla bla incurring a bunch of cost for little gain. 2017 L405 AB SDV8
Post #692433 12th May 2024 10:57am
