![]() | Home > Wheels & Tyres > Largest possible L405 tyres with smallest possible rims |
Flyboy0902 Member Since: 27 Mar 2024 Location: Warwick Posts: 31 ![]() ![]() ![]() |
Hi all,
Thanks! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
255/60/r20 from a new defender fit the L405 ( at least the Pirelli all seasons do) V8 or else ... |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Hi Fisha, do you have the Defender alloys fitted to your L405? If so, do you have any pics? 2019 L405 SDV8 Autobiography
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
Quite a few owners have fitted 275/55R20. |
Just a word of caution for big tyres... The other day I had a combined height sensor and airbag fail and the car dropped to it's bump stops. I was able to drive a short distance to a safe pull over but when I was fixing it I noticed a bit of rub on the arches on my slightly oversized 255/55/R20 so I reckon anything bigger may have rendered the car stuck in the road? 2012 TDV8 Vogue (L322) |
Some pictures … I actually quite like them. They have a slightly wider offset, which counters the smaller rim size looking lost in the arches. I’ve not noticed rubbing as yet. Makes for a nice smooth ride compared to the 22” rims I have.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
285/50/20 work well and are probably the largest you can go risk free without rubbing in all modes - plus you can get a spare in the tyre well - any bigger and it’s very unlikely you will 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
bdd123 Member Since: 27 Apr 2024 Location: Colorado Posts: 13 ![]() ![]() ![]() |
Slightly surprised by this as it is .3 larger diameter and.8" narrower. What is your wheel and wheel offset? Current: 2017 L405 ATB, 2016 LR4 SE Past: 2001 RRR H&H, 1993 RRC SE, 1989 RRC, 1990 RRC, 1995-97-98 D1 |
TJNZ Member Since: 17 Apr 2022 Location: Auckland Posts: 19 ![]() ![]() ![]() |
I put these on mine after sourcing some rims and they fit well. I have also sourced a 20inch spare rim but have left the 255 55 50 tyre on it as it was very close in diameter and fits in the spare wheel well. I wasnt sure the 285 would fit there in terms of the height and it may protrude to high for the trunk cover. Did yours fit ok?
2011 L322 Vogue SE 4.4 TDV8 |
Yes - just - Cooper AT3, 285/50/20, that was on my previous L405 - pre facelift - not tried on the latest one, just left the std spare in as it’s a space saver and there’s a foam infill beneath - I’ve never needed to use a spare on a RR in at least 20 years - think the last time was on a Classic in 1995 - now I’ve just given it the kiss of death and jinxed everything 🙈😂
Thanks |
