Home > Wheels & Tyres > Largest possible L405 tyres with smallest possible rims |
Flyboy0902 Member Since: 27 Mar 2024 Location: Warwick Posts: 25 |
Hi all,
27th Mar 2024 9:58am |
Thanks! |
27th Mar 2024 10:22am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1405 |
255/60/r20 from a new defender fit the L405 ( at least the Pirelli all seasons do) V8 or else ... |
27th Mar 2024 7:34pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
Hi Fisha, do you have the Defender alloys fitted to your L405? If so, do you have any pics? 2019 L405 SDV8 Autobiography
28th Mar 2024 8:18am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2551 |
Quite a few owners have fitted 275/55R20. |
28th Mar 2024 8:33am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Just a word of caution for big tyres... The other day I had a combined height sensor and airbag fail and the car dropped to it's bump stops. I was able to drive a short distance to a safe pull over but when I was fixing it I noticed a bit of rub on the arches on my slightly oversized 255/55/R20 so I reckon anything bigger may have rendered the car stuck in the road? 2012 TDV8 Vogue (L322) |
28th Mar 2024 9:23am |
Some pictures … I actually quite like them. They have a slightly wider offset, which counters the smaller rim size looking lost in the arches. I’ve not noticed rubbing as yet. Makes for a nice smooth ride compared to the 22” rims I have.
28th Mar 2024 5:38pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
285/50/20 work well and are probably the largest you can go risk free without rubbing in all modes - plus you can get a spare in the tyre well - any bigger and it’s very unlikely you will 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
6th Apr 2024 7:45am |
bdd123 Member Since: 27 Apr 2024 Location: Colorado Posts: 11 |
Slightly surprised by this as it is .3 larger diameter and.8" narrower. What is your wheel and wheel offset? Current: 2017 L405 ATB, 2016 LR4 SE Past: 2001 RRR H&H, 1993 RRC SE, 1989 RRC, 1990 RRC, 1995-97-98 D1 |
3rd May 2024 1:48pm |
TJNZ Member Since: 17 Apr 2022 Location: Auckland Posts: 19 |
I put these on mine after sourcing some rims and they fit well. I have also sourced a 20inch spare rim but have left the 255 55 50 tyre on it as it was very close in diameter and fits in the spare wheel well. I wasnt sure the 285 would fit there in terms of the height and it may protrude to high for the trunk cover. Did yours fit ok? 2011 L322 Vogue SE 4.4 TDV8 |
4th May 2024 10:36am |
Yes - just - Cooper AT3, 285/50/20, that was on my previous L405 - pre facelift - not tried on the latest one, just left the std spare in as it’s a space saver and there’s a foam infill beneath - I’ve never needed to use a spare on a RR in at least 20 years - think the last time was on a Classic in 1995 - now I’ve just given it the kiss of death and jinxed everything 🙈😂
4th May 2024 10:15pm |
Thanks for this. Admittedley it was a quick look but the stock 275 22's looked almost flush to the top of the trunk floor. I think I'll do similar to you and just leave the 255 55 20 rim and tyre in there as a backup. My OCD will have me respraying the spare bla bla incurring a bunch of cost for little gain. 2017 L405 AB SDV8
12th May 2024 9:57am |
