Well the zip-ties are off and it's ALIVE !
Started with no issues or gremlins - coolant system bled with no problem
Let the engine get up to temperature with eyes on storks looking for leaks etc
Thankfully all good
So after a few days work it now appears sorted
My little check list :
Oil
Oil Filter
2 x Air filters
8 x spark plugs
8 x coil packs
Water pump
Anti-freeze
oil cooler gasket
2 x inlet manifold gaskets
Supercharger gasket
Supercharger oil change
Supercharger Coupler replace
Throttle body gasket
4 x front Y piece O rings
Alt belt
Superseded water pump bypass hose kit
Front crank seal
2 x updated camchain tensioners
Symposer delete
2009 - L322 5.0 S/C Autobiography
