It's a brass olive on plastic pipe, my struts came with new olives and nuts, I cut about 10mm off the end of the pipe till it was clean, then new nut and olive and do it up being carefully not to cross the thread, although it does fit very well and it's unlikely you will...
Then just do it up, make sure the olive is far enough down the pipe, it doesn't have to be real tight to seal, do it with fingers then about 1/2 to 1 turn, you will "feel" when it's done.
I was apprehensive about the first time I did one but it's one of those jobs you can over think and worry about and it's very straight forward....
Good luck... Pete
