Home > Technical (L322) > Air spring connector advice
JayGee
Will be fitting a new front pair of struts soon and also the rears and the only thing I'm especialy concerned with is the integrity of the hose seal as it goes into the fitting to ensure it's leak free and I don't have to redo the job.... Any advice / tips are welcome on how to not mess this up Thumbs Up 2012 TDV8 Vogue (L322)
Post #688411 19th Mar 2024 3:34pm
It's a brass olive on plastic pipe, my struts came with new olives and nuts, I cut about 10mm off the end of the pipe till it was clean, then new nut and olive and do it up being carefully not to cross the thread, although it does fit very well and it's unlikely you will...
Then just do it up, make sure the olive is far enough down the pipe, it doesn't have to be real tight to seal, do it with fingers then about 1/2 to 1 turn, you will "feel" when it's done.
I was apprehensive about the first time I did one but it's one of those jobs you can over think and worry about and it's very straight forward....
Good luck... Thumbs Up Pete
Post #688423 19th Mar 2024 5:03pm
Historical advice was to leave the connection alone and refit with the same one that came off (not disturbing the olive on the pipe, keeping the original nut). This had worked OK for me when changing the front struts, and when removing/replacing the rear bags. Of course, this requires that the pipe/olive/nut is not damaged in any way / was not previously leaking etc. .
Post #688462 19th Mar 2024 9:49pm
kevinp
Did mine not long ago. Access to the airline is good compared to the rear air bags as long as you have a short 12mm spanner.
I used my old connector and all is good.
Post #688480 20th Mar 2024 7:14am
