Home > Technical (L322) > Air spring connector advice |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
It's a brass olive on plastic pipe, my struts came with new olives and nuts, I cut about 10mm off the end of the pipe till it was clean, then new nut and olive and do it up being carefully not to cross the thread, although it does fit very well and it's unlikely you will...
19th Mar 2024 4:03pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Historical advice was to leave the connection alone and refit with the same one that came off (not disturbing the olive on the pipe, keeping the original nut). This had worked OK for me when changing the front struts, and when removing/replacing the rear bags. Of course, this requires that the pipe/olive/nut is not damaged in any way / was not previously leaking etc. .
19th Mar 2024 8:49pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
Did mine not long ago. Access to the airline is good compared to the rear air bags as long as you have a short 12mm spanner.
20th Mar 2024 6:14am |
