Home > Maintenance & Mods (L322) > ZF Gear Box Oil
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
ZF Gear Box Oil
Hi all. I know this subject has been done to death but I have a technical question that I hope anyone in the know might be able to answer.
Do you know what the difference is between the below two oils. Are they the same company or is the one just a rip off. The reason I ask is because the one that says ZF Getriebe is half the price of the other well known labeled ZF Lifeguard Fluid 6 and the part numbers are different.
Any help welcome, Cheers…..
 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687988 13th Mar 2024 1:31pm
RRPhil
They're the same thing. The bottle at the bottom is the latest packaging, so if you get the top one it's old stock. If you had both bottles in front of you you'd see that they have a date printed on them and the age difference would be clear.
Phil
Post #688006 13th Mar 2024 5:14pm
PDC
Cheers Phil, because the oil was been sold so much cheaper than everyone else I thought the worse, but now you have reassured me I will get and order it with the pan kit.
Cheers once again. 👍🏻 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #688010 13th Mar 2024 6:14pm
garyRR
Just make sure the fluid is from a reputable seller, so it won't be cheap stuff put in a ZF labeled bottle. 2015 Range Rover Autobiography 4.4 SDV8
Post #688014 13th Mar 2024 6:49pm
PDC
It's from AUTODOC I've not really heard of them before apart from on Sam's Motors, so hopefully they should be OK! I will make sure that they are sealed when they arrive. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #688020 13th Mar 2024 7:35pm
