Home > Maintenance & Mods (L322) > ZF Gear Box Oil |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
They're the same thing. The bottle at the bottom is the latest packaging, so if you get the top one it's old stock. If you had both bottles in front of you you'd see that they have a date printed on them and the age difference would be clear.
13th Mar 2024 5:14pm |
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 73 |
Cheers Phil, because the oil was been sold so much cheaper than everyone else I thought the worse, but now you have reassured me I will get and order it with the pan kit.
13th Mar 2024 6:14pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
Just make sure the fluid is from a reputable seller, so it won't be cheap stuff put in a ZF labeled bottle. 2015 Range Rover Autobiography 4.4 SDV8 |
13th Mar 2024 6:49pm |
It's from AUTODOC I've not really heard of them before apart from on Sam's Motors, so hopefully they should be OK! I will make sure that they are sealed when they arrive. 2010 RR Autobiography 5.0 SC
13th Mar 2024 7:35pm |
