![]() | Home > In Car Electronics (L322) > Help with Android head Unit Install on '04 L322 |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
One part of the loom should be quite long. It needs feeding down through the dash to a module behind the glove box.
jlmiami Member Since: 02 Mar 2024 Location: Miami, Florida Posts: 10 ![]() ![]() ![]() |
Thanks for the reply! So you're saying that there is a brain under the glovebox that this system speaks to? Sorry i'm a near noob in the car audio depo. I have reached out to the seller as well. Thanks! |
It might be different on your 04 and I've only fitted systems on an 06 and 10 before, but on those vehicles there is a module tucked right up behind the glove box by the bulkhead, barely visible. On the loom supplied with the screen, there may be a part of it with a longer cable on it. If so, this will probably be the bit that plugs into the module behind the glove box. 2015 Range Rover Autobiography 4.4 SDV8 |
Ah! Yea, unfortunately, there is no loom provided :/
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8491 ![]() ![]() ![]() |
You need the 5 mtr extension lead which goes through to the rear cubby...
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
I know on my L320 due to the fibre network I had to use this bad boy
