Home > Maintenance & Mods (L322) > Rear brake calipers
mgrover
Rear brake calipers
Is it worth refurbing these or just replacing them entirely? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #686746 29th Feb 2024 9:57am
JayGee
Are they seized? 2012 TDV8 Vogue (L322)
Post #686748 29th Feb 2024 10:29am
mgrover
my rear left is yeah, currently driving around with lovely metal on metal.
ive got the full compliment at the moment to basically redo all the suspension of the rear with fresh pads/discs.
so seemed sensible to refurb the calipers. Its actually a sport Sad
Post #686751 29th Feb 2024 10:56am
JayGee
It's not a difficult job with the right tools although depends on how badly the piston is siezed in the bore and if there is any corrosion to the bore. Do you have a compressor to blow the pistons out? 2012 TDV8 Vogue (L322)
Post #686758 29th Feb 2024 1:07pm
mgrover
i do have a compressor, so should be simple enough, is it worth checking them, if the corrosion isnt too bad to clean them down/respray then fresh piston/seals? and if fooked then replace.
currently i imagine the car will be on stirrups for a few weeks anyways. Its actually a sport Sad
Post #686759 29th Feb 2024 1:09pm
DrRob
Threw mine in the bin and replaced with new TRW ones from site sponsor Advanced Factors
Discount code AF4LRP
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686760 29th Feb 2024 1:24pm
mgrover
its tempting but close to 400quid vs like 60quid and a couple of hours work
especially when i can throw that 400quid at the subframe bushings Its actually a sport Sad
Post #686763 29th Feb 2024 1:38pm
JamesDarby
United Kingdom 2011 Range Rover Autobiography TDV8 Buckingham Blue
I just rebuilt my rear callipers and its not a difficult job with new pistons. (With new Brembo disks and pads). The seized one would not blow out with air.
When its still on the car, remove the pads and use the brake pedal to push the piston out a reasonable way. Don't go too made and push it all the way out a the fluid will go everywhere.
To get mine out I had to get a large stilson wrench on the piston and managed to get it to rotate. Then rotated and pulled with a pair of mole grips on the pisiton.
After bleeding I pushed hard on the pedal and the small bit of solid pipe on the flexible on the top wishbone burst!
So I was luck it happened then and not when I'm towing the caravan in a few weeks.
So I would change the flexible on both sides too if they look a little rusty.
Oh and isn't the pad wear indicator the worse design ever. Whoever though of hiding the connector inside a box up behind the wheel arch plastic. 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #686770 29th Feb 2024 2:16pm
mgrover
think ama change the brake pipes too.
what is the word on the street on em? get oem or suffer type deal or will after market do? Its actually a sport Sad
Post #686777 29th Feb 2024 3:00pm
Wiltshire130
United Kingdom 2018 Range Rover Autobiography 5.0 SC V8 Corris Grey
Definetly change the brake pipes - mine were ready to fracture when I took it all apart.
An alternative method it you already have the calipers removed and compressed air will not move the pistons is to screw an M10 x 1 grease nipple in to where the bleed nipple goes and with the inlet sealed off (mole grips on a rubber section - you're going to change them anyway) pump grease in. This will push the piston out without too much effort. L405 2018 5.0 S/C
Post #686808 29th Feb 2024 6:57pm
mgrover
is there a particular brand or best to just grab some from dealers? Its actually a sport Sad
Post #686812 29th Feb 2024 7:33pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
AUTODOC do regular offers on TRW branded rear calipers. I saw these last week at around the £90 mark ( each ) after a 45% discount. Perhaps, keep/ refurb the carriers and traveler pins and fit a pair of new ones at that price. TDV8 4.4 2012
Post #686813 29th Feb 2024 7:59pm
DrRob
Mine were a fraction of that price Shocked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686823 29th Feb 2024 8:58pm
Ramblin Man
FYI : TRW branded Rear Calipers are discounted on AutoDoc today to ~£90 each. That’s a 70% discount!
Right : https://m.autodoc.co.uk/trw/2185309
Left : https://m.autodoc.co.uk/trw/2185308
Use code : AC110673399 to get additional £10 off ( only valid for today )
Note: I have no association with auto doc other than being a customer. TDV8 4.4 2012
Post #687124 4th Mar 2024 10:47am
