Home > Maintenance & Mods (L322) > Deadlock issue work in progress
Jimmy86
Hi All,
First job on the to do list for my new to me L322 is sort out the deadlocked drivers door.
I've got to the point in the pictures by pulling back the door card and removing some of the plastic lock housing but nothing I seem to do from here seems to work. Anyone got any suggestions.
Is the deadlock controlled by the piece in the red circle?
Cheers
Post #686632 27th Feb 2024 8:28pm
mjdronfield
Can’t you access something on the side of the door with the rear passenger door open, in the latch area? I seem to remember a similar post on here at some point….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #686637 27th Feb 2024 9:07pm
Jimmy86
Thanks. Did have a quick look at that but from what I understand that will only solve the issue if its due to the handle not engaging the lock. YouTube seems to suggest the only say to release the deadlock is by braking the casing on top and moving the latch. I can't seem to see what I'm meant to be releasing though. Perhaps need better access??
Post #686642 27th Feb 2024 9:50pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I did it be removing the trim along the drivers door window, this allows access inside the door in the gap between the window and the door (from the outside) using a long reach screwdriver. With the screwdriver located on the plastic top of the locking mechanism, give it a good clout to break the plastic. This allows you to poke about just inside the top of the locking mechanism. I just fiddled for a bit and then it suddenly popped when I got the right bit and the door opened. It's a bit hit and miss until you've done it once, but it worked for me.
Note: this does not reset the deadlock and it will still be faulty, so next time you lock it it will jam again, sadly you need a replacement locking mechanism. They're about £300 new (I thought a used one might do exactly the same as the old one).
My thread: https://www.fullfatrr.com/forum/topic68341.html
I have tried to see what went wrong on the old lock, but failed miserably. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #686747 29th Feb 2024 9:22am
Jimmy86
That's great, thank you.
Post #686749 29th Feb 2024 9:44am
