Home > Maintenance & Mods (L322) > Deadlock issue work in progress |
Can’t you access something on the side of the door with the rear passenger door open, in the latch area? I seem to remember a similar post on here at some point….
27th Feb 2024 9:07pm |
Jimmy86 Member Since: 27 Feb 2024 Location: East midlands Posts: 9 |
Thanks. Did have a quick look at that but from what I understand that will only solve the issue if its due to the handle not engaging the lock. YouTube seems to suggest the only say to release the deadlock is by braking the casing on top and moving the latch. I can't seem to see what I'm meant to be releasing though. Perhaps need better access?? |
27th Feb 2024 9:50pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 537 |
I did it be removing the trim along the drivers door window, this allows access inside the door in the gap between the window and the door (from the outside) using a long reach screwdriver. With the screwdriver located on the plastic top of the locking mechanism, give it a good clout to break the plastic. This allows you to poke about just inside the top of the locking mechanism. I just fiddled for a bit and then it suddenly popped when I got the right bit and the door opened. It's a bit hit and miss until you've done it once, but it worked for me.
29th Feb 2024 9:22am |
That's great, thank you. |
29th Feb 2024 9:44am |
