Home > Technical (L322) > N/S/F drive shaft
Shaunj69
England 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
N/S/F drive shaft
Hi
I have got an issue with my FF, In Dec my FF started to throw the n/s/f drive shaft out.
So i got her home the pushed the shaft back in and all good for a few days then boom out again.
So got a new shaft with a new snap ring fitted it and all good for a full week, then Sunday it went again.
I have had a look at replacing the front diff but its a big job on the road out side the house.
So my question is do any of you have any reconditions where i can get it fitted and do you think i am going down the right path?
All the best and thanks in advance
by the way i am in Yate Bristol. L322 TDV8 2011 Autobiography
Working for an OE aftermarket car parts suppler
Post #686597 27th Feb 2024 2:10pm
Epson Green
If you are saying the driveshaft is coming out of the front diff I would think that would only be possible if one of the control arms were broken? But then the car would be undriveable. Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #686640 27th Feb 2024 10:21pm
Shaunj69
Hi Epson Green
like you say about the control arms, yeah all good there.
Around two years ago the car did had the diff replaced by the garage i brought the car from, Diff whining.
When i fitted the new drive shaft i had a look at the 4 bolts that hold the diff to the sump, and found that the bolts had come lose. Ok they are only done up to 50nm then 90* but i thought "yes that's the problem". So done them up and put the new shaft in, but like a say a week later out it came.
So my last thought is there is something in side the diff that has worn and moving around, so i am down to a diff change.
The strange thing is those the diff on the car did not make any noise before it started pushing its drive shafts out. Still booked into a garage Wednesday 6/3/24.
Many thanks L322 TDV8 2011 Autobiography
Post #686657 28th Feb 2024 9:48am
dingg1
Its been known that some pattern part ds are slightly smaller than the original ones fitted by land rover, bet that's the problem here.
Post #686658 28th Feb 2024 10:07am
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey Shaun I'm over in Yate way when I'm not working. You could try MJ fewes in wooton under edge, they are very good.
Post #686701 28th Feb 2024 7:25pm
Shaunj69
Good afternoon all
So my saga continues!!!!
After 2 new drive shafts and a new/recon front diff its still throwing the shaft out.
All the n/s suspension has been replaced, so no movement on the wheel side. I just don't know what else to do.
Thanks L322 TDV8 2011 Autobiography
Post #696071 12th Jul 2024 2:36pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Just thinking outside the box, do you think there is some misalignment due to a crash or something affecting the diff mounting and it's relationship to the wheel hub ?
Or could it be a bush / bracket in the diff mounting area gone bad forcing the diff away from the hub, missing spacer somewhere.
Just thinking that if the shaft is in and done up tight, for it to fall out something must be moving under stress or be missing in the first place or bent out of true.
You could try taking some very accurate measurements of the diff to hub distances and the front track as accurately as you can and comparing that to an identical car.
What does it look like from the front, wheels straight on level ground, does it look like the car is actually straight, should be able to tell if you can photograph and check the wheel inset compared left and right, are they identical or is the NS wheel / hub actually secured in the wrong place.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #696072 12th Jul 2024 3:03pm
dingg1
Are they pattern parts?
Post #696074 12th Jul 2024 4:28pm
Rambles
https://www.fullfatrr.com/forum/topic55527.html
Post #696158 14th Jul 2024 10:39am
Shaunj69
Hi mate
That was interesting reading!
I will have a look and do some measuring.... L322 TDV8 2011 Autobiography
Post #696653 22nd Jul 2024 1:28pm
Shaunj69
Yeah pattern part L322 TDV8 2011 Autobiography
Post #696654 22nd Jul 2024 1:29pm
dhallworth
Pattern parts will be your problem. I guarantee the pattern parts are slightly shorter than the originals. It's been documented on here somewhere before I'm sure.
I'd be trying a genuine LR used shaft from eBay or buying a genuine LR one and I'd put money on it not happening again.
Post #696656 22nd Jul 2024 3:40pm
dingg1
Agreed, see my post above 5 months ago ^^^^
Post #696657 22nd Jul 2024 3:58pm
Shaunj69
Look like this shaft is going back.
E-bay here i come and i will do a rebuild with new CV and boots
Many thanks all and i will keep you all updated Thumbs Up L322 TDV8 2011 Autobiography
Post #696709 23rd Jul 2024 11:11am
