![]() | Home > Technical (L322) > N/S/F drive shaft |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
If you are saying the driveshaft is coming out of the front diff I would think that would only be possible if one of the control arms were broken? But then the car would be undriveable. Kevin
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Hi Epson Green
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Its been known that some pattern part ds are slightly smaller than the original ones fitted by land rover, bet that's the problem here. |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 724 ![]() ![]() ![]() |
Hey Shaun I'm over in Yate way when I'm not working. You could try MJ fewes in wooton under edge, they are very good. |
Good afternoon all
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Just thinking outside the box, do you think there is some misalignment due to a crash or something affecting the diff mounting and it's relationship to the wheel hub ?
Are they pattern parts? |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Hi mate
Yeah pattern part L322 TDV8 2011 Autobiography Working for an OE aftermarket car parts suppler |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3195 ![]() ![]() ![]() |
Pattern parts will be your problem. I guarantee the pattern parts are slightly shorter than the originals. It's been documented on here somewhere before I'm sure.
Agreed, see my post above 5 months ago ^^^^ |
Look like this shaft is going back.
