Home > Technical (L405) > Coolant leak - not the usual suspects |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 264 |
Hi Andy
15th Feb 2024 3:52pm |
Andy_Butler Member Since: 21 Mar 2023 Location: Bury st Edmunds Posts: 19 |
I changed the o-ring in the fitting. It was very flattened and starting to crack |
15th Feb 2024 4:03pm |
Hi Andy
15th Feb 2024 4:14pm |
I’m now doubting my own fix. I was able to see coolant on the lhs of the cooler in the V with a camera. However, now I think about it, the pipe is on the rhs so where did the water come from to get to the lhs?
15th Feb 2024 6:23pm |
PLC Member Since: 23 May 2022 Location: Stafford Posts: 18 |
the egr coolant pipe runs on the lhs under the egr pipe that go to the doughnut |
15th Feb 2024 6:41pm |
Thanks 👍 this is all new to me, what’s the doughnut? Intake? |
15th Feb 2024 6:45pm |
big black intake sitting on top of the engine |
15th Feb 2024 6:48pm |
15th Feb 2024 8:24pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 87 |
I've had similar, and it was caused by the heater pipes joining the small plastic manifold next to the oil cooler.
15th Feb 2024 8:29pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1260 |
My leak was from flattened o-rings that are in the pipes at the front of the V around the thermostat area. The coolant dripped from the connection along the V and down the back of the bell housing.
16th Feb 2024 12:01am |
Sorry Andy, I didn’t mean to hijack your thread. Just thought it useful to keep similar issues in the same place. |
16th Feb 2024 6:59am |
Snap! 45x4mm o-rings were flat. As you said coolant leaked into the back of the pump housing and then into the V. Tricky to find but very easy to fix. Absolutely worth doing for anyone who has drained the coolant. |
29th Feb 2024 1:54pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2322 |
The originals aren't round, they are a flat ring. I used 45 x 3.5 Viton 75 but very recently took the opportunity to replace both hoses along with all other hoses in the V as the radiator had developed a leak. |
29th Feb 2024 8:49pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
A cheap pressure test kit can be bought on Ebay or Amazon... Takes the guesswork out of the equation...
1st Mar 2024 1:04am |
