Home > Technical (L405) > Coolant leak - not the usual suspects
Andy_Butler
Hi All,
I’ve had a slowish coolant leak where the juice can be seen in the vee and dribbling down the bellhousing at the back. I changed the oil cooler and the o-ring for the coolant pipe which feeds it but I still seem to have the same leak. Is there anything else in at area I should be looking at?
4.4sdv8 by the way
Thanks
Post #685671 15th Feb 2024 11:05am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Hi Andy
I’ve got the same issue and just replaced the cooler etc. 90% finished.
There’s two coolant pipes going into the cooler, did you change the one on the rhs?
See photo
Post #685684 15th Feb 2024 3:52pm
Andy_Butler
I changed the o-ring in the fitting. It was very flattened and starting to crack
Post #685685 15th Feb 2024 4:03pm
Richie N
Hi Andy
Of course the rear pipe is oil not coolant 🤦
Post #685686 15th Feb 2024 4:14pm
Richie N
I’m now doubting my own fix. I was able to see coolant on the lhs of the cooler in the V with a camera. However, now I think about it, the pipe is on the rhs so where did the water come from to get to the lhs?
I’ll finish putting it back together and cross my fingers.
Post #685696 15th Feb 2024 6:23pm
PLC
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
the egr coolant pipe runs on the lhs under the egr pipe that go to the doughnut
Post #685702 15th Feb 2024 6:41pm
Richie N
Thanks 👍 this is all new to me, what’s the doughnut? Intake?
Post #685704 15th Feb 2024 6:45pm
PLC
big black intake sitting on top of the engine
Post #685705 15th Feb 2024 6:48pm
Richie N
Post #685715 15th Feb 2024 8:24pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I've had similar, and it was caused by the heater pipes joining the small plastic manifold next to the oil cooler.
I changed the heater pipes and the manifold.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #685717 15th Feb 2024 8:29pm
fisha
My leak was from flattened o-rings that are in the pipes at the front of the V around the thermostat area. The coolant dripped from the connection along the V and down the back of the bell housing.
https://www.fullfatrr.com/forum/topic66813.html V8 or else ...
Post #685737 16th Feb 2024 12:01am
Richie N
Sorry Andy, I didn’t mean to hijack your thread. Just thought it useful to keep similar issues in the same place.
Post #685743 16th Feb 2024 6:59am
Andy_Butler
Snap!
45x4mm o-rings were flat. As you said coolant leaked into the back of the pump housing and then into the V. Tricky to find but very easy to fix. Absolutely worth doing for anyone who has drained the coolant.
Post #686765 29th Feb 2024 1:54pm
GraemeS
Australia
The originals aren't round, they are a flat ring. I used 45 x 3.5 Viton 75 but very recently took the opportunity to replace both hoses along with all other hoses in the V as the radiator had developed a leak.
Post #686819 29th Feb 2024 8:49pm
A cheap pressure test kit can be bought on Ebay or Amazon... Takes the guesswork out of the equation...
Simply buy a universal kit, attach the hand pump and pressurise the system. Then inspect for leaks... The quicker the pressure drops, the bigger the leak! Simples... Thumbs Up
Post #686849 1st Mar 2024 1:04am
