Home > Technical (L322) > Calibration offset height sensors (Adaptive Damping ADCM) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1219 |
If you have just put the new sensors on they could be flipped in the wrong orientation. |
10th Feb 2024 1:10pm |
Red Desert Member Since: 15 Apr 2012 Location: Lake Constance Posts: 20 |
The spare part numbers for the front right/left sensors are identical to those for the rear right/left. You cannot mix up the sensors or mount them incorrectly. Things were different with the first sensor types. I think it should be possible to set the system to "0", i.e. factory setting. But I can't find anything about it. The background to the whole operation is the adaptive dynamics error message. I have a good friend who is a master at Land Rover, but anyway people are hopelessly overwhelmed with problems like this. The entire system is not particularly complicated in my opinion. Maybe my expectations of the specialist staff are simply too high. |
10th Feb 2024 1:22pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 439 |
I think what's being suggested is the arm of one or more sensors is in the wrong position, rather than the sensor themselves being in the wrong location(s).
10th Feb 2024 1:28pm |
The arms would collide with the subframes, making it impossible. By the way, the error messages after replacing the sensors are identical to those before the replacement, i.e. with the old sensors. All arms are orientated app. 90 degress to the outside of the vehicle. |
10th Feb 2024 2:33pm |
No, I don't mean that they've flipped a whole 180 degrees! As you say that'd be impossible!
11th Feb 2024 2:14pm |
The connectors are only detached in these photos
11th Feb 2024 2:53pm |
New (used) ECU LR025881 and all faults are gone
20th Feb 2024 10:53am |
