Home > Technical (L405) > Water in fuel
Jordie Barrett's sock
Water in fuel
Warning came up today. Driving fine, got home and went out later and no warning.
Sounds a bit dramatic but I'm guessing a sensor somewhere has picked up a bit of moisture somewhere and it's nothing to panic about?
Post #682639 13th Jan 2024 9:07pm
mjdronfield
I believe the sensor is under the fuel filter. Mine did that once, when I splashed through a few deep puddles….
See how you go. Might never come up again….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #682641 13th Jan 2024 9:12pm
V8 Bob
It is a known fault on L322 it could actually be water in fuel , have you run the tank very low or filled up at a different garage lately? On L322 it is normally a sensor in the housing that fails if I remember correctly lack of parts means replacing the housing which costs circa £300 plus labour. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #682659 14th Jan 2024 9:25am
Driven a couple of hundred miles since. It hasn't reappeared and all is good.
Fingers crossed.
Post #682769 15th Jan 2024 11:52am
