![]() | Home > Technical (L405) > Water in fuel |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7899 ![]() ![]() ![]() |
I believe the sensor is under the fuel filter. Mine did that once, when I splashed through a few deep puddles….
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
It is a known fault on L322 it could actually be water in fuel , have you run the tank very low or filled up at a different garage lately? On L322 it is normally a sensor in the housing that fails if I remember correctly lack of parts means replacing the housing which costs circa £300 plus labour. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Jordie Barrett's sock Member Since: 01 Nov 2023 Location: South West Posts: 24 ![]() ![]() ![]() |
Driven a couple of hundred miles since. It hasn't reappeared and all is good.
