Home > Technical (L405) > Water in fuel
Jordie Barrett's sock
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Water in fuel
Warning came up today. Driving fine, got home and went out later and no warning.
Sounds a bit dramatic but I'm guessing a sensor somewhere has picked up a bit of moisture somewhere and it's nothing to panic about?
Post #682639 13th Jan 2024 10:07pm
mjdronfield
I believe the sensor is under the fuel filter. Mine did that once, when I splashed through a few deep puddles….
See how you go. Might never come up again….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #682641 13th Jan 2024 10:12pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
It is a known fault on L322 it could actually be water in fuel , have you run the tank very low or filled up at a different garage lately? On L322 it is normally a sensor in the housing that fails if I remember correctly lack of parts means replacing the housing which costs circa £300 plus labour. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #682659 14th Jan 2024 10:25am
Driven a couple of hundred miles since. It hasn't reappeared and all is good.
Fingers crossed.
Post #682769 15th Jan 2024 12:52pm
