Home > In Car Electronics (L405) > Poor DAB reception |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 130 |
I have the same issue, which also extends to FM reception. It's rubbish. Basically unusable.
4th Jan 2024 7:17am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
i suspect i had water ingress from the shark fin on the roof....some silicon around the base of the fin and it seems to have solved my problem...
4th Jan 2024 8:25am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1396 |
If you were getting water in the shark fin, were you not also seeing water ingress on the head lining ? V8 or else ... |
5th Jan 2024 5:10pm |
no water inside...i think it was more 'moisture' than full scale water....the sealing did make a difference though.. ... - .- -.
5th Jan 2024 5:25pm |
