![]() | Home > In Car Electronics (L405) > Poor DAB reception |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 137 ![]() ![]() ![]() |
I have the same issue, which also extends to FM reception. It's rubbish. Basically unusable.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
i suspect i had water ingress from the shark fin on the roof....some silicon around the base of the fin and it seems to have solved my problem...
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1434 ![]() ![]() |
If you were getting water in the shark fin, were you not also seeing water ingress on the head lining ? V8 or else ... |
no water inside...i think it was more 'moisture' than full scale water....the sealing did make a difference though.. ... - .- -.
