Home > In Car Electronics (L405) > Poor DAB reception
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Poor DAB reception
Having recently changed from a new Defender to a 2019 L405 AB it’s been very noticeable that the DAB radio loses signal a lot more frequently. Listening to the same station on the same routes as in the Defender the L405 reception drops out considerably more often.
Is this just standard with the L405 or do I have an issue? 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #681817 3rd Jan 2024 8:26pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I have the same issue, which also extends to FM reception. It's rubbish. Basically unusable.
Interested to know how to fix it.
Mine is a 2015 Vogue.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #681833 4th Jan 2024 7:17am
i suspect i had water ingress from the shark fin on the roof....some silicon around the base of the fin and it seems to have solved my problem...
it was strange that in the summer months reception was ok, when it rained it wasnt... ... - .- -.
Post #681838 4th Jan 2024 8:25am
fisha
If you were getting water in the shark fin, were you not also seeing water ingress on the head lining ? V8 or else ...
Post #681936 5th Jan 2024 5:10pm
no water inside...i think it was more 'moisture' than full scale water....the sealing did make a difference though.. ... - .- -.
Post #681937 5th Jan 2024 5:25pm
