![]() | Home > Maintenance & Mods (L405) > Reverse light brightness poor |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 494 ![]() ![]() ![]() |
I also think this. I never worked out what a good solution should be or where is mount extra lights. SDV8 AB MY 2020
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
this is for a L405 Andy |
apologies, I must read properly, sorry for the confusion.
GaryR Member Since: 30 Jul 2020 Location: Queensland Posts: 20 ![]() ![]() ![]() |
I agree reverse lighting is not good. I have made a bracket that holds a mini light bar that inserts into the fixed tow bar receiver and connects to the tow plug. Obviously works well when not towing, is removable and doesn’t reduce the departure angle. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1687 ![]() ![]() ![]() |
Totally agree.
Salsbury Member Since: 19 Jun 2022 Location: Alberta Posts: 109 ![]() ![]() ![]() |
I've pondered this too but yet to take action. I think a solution is one of those brackets that holds two LED cubes onto the tow shaft - you can find many on Amazon. Being a range rover, I'd get a pro auto electrician to wire it up.
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 800 ![]() ![]() |
If it's mainly a problem when reversing onto a drive, what about a couple of LED sensor lights? I've got 2 down the side of the house with solar panels on the top, they weren't expensive and are still going strong after about 5 years.
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 164 ![]() ![]() ![]() |
Do the later facelift rear lights work better? |
I don't think so as it is what I have. I know and have used the brake light to light up behind better.
@stan
I fitted a strip led light but have since damaged it and need another cover, the lights ok but snapped the clips on the cover.
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 160 ![]() ![]() ![]() |
Sorry - I had my L322 hat on(disregard the bottom unless you have an L322 as well)
