![]() | Home > Maintenance & Mods (L322) > Mannol Engine Oil Query |
Needs to be ACEA C1 (Low Ash) / WSS-M2C934-B 2012 TDV8 Vogue (L322) |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 413 ![]() ![]() ![]() |
ok, cool - I´ll stick that in the next two oil changes for the MX-5 then.
John-suusex Member Since: 31 Oct 2019 Location: Sussex Posts: 53 ![]() ![]() |
https://www.ebay.co.uk/itm/304685626380?mk...media=COPY
General Member Since: 22 Jun 2020 Location: UK Posts: 15 ![]() ![]() ![]() |
I always use Smith & Allan
That's fine as your 2008 doesn't have a DPF so any good quality 5w-30 will do the job 2012 TDV8 Vogue (L322) |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Likewise. 20K miles on S&A so far. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
Not 20k miles since the last oil change I hope 2012 TDV8 Vogue (L322) |
Is that what I said?
Sorry for suggesting it and not putting a |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
3disco Member Since: 02 Oct 2021 Location: Devon Posts: 4 ![]() ![]() |
I have done exactly the same and have been told it’s an old photo of a barrel and that it needs the c1so I guess that’s another barrel going back! |
Yes!
IndividualM5 Member Since: 01 Mar 2024 Location: Yorkshire Posts: 1 ![]() ![]() ![]() |
I too am looking for the correct ‘reasonably priced’ oil to use in my 2017 4.4sdv8 and Mannol seems to fit the bill. Surely, it’s the same oil even though the label no longer has the STJLR.03.5005 quoted on it? I’m actually erring towards the 7908 Energy Premium, which is less than £60 for 20 litres. I’ve checked JLR recommended lubricants and they do say that any ACEA C2 oil may be used if STJLR.03.5005 is not available 🤔 |
AFAIK the manual says you can top up with C2 in an emergency but it doesn't say you can use it for an oil change. C2 is mid SAPS C1 is Low SAPS - if you have a DPF you should not be using anything but low SAPS. Smith & Allan do reasonably priced 5w-30 C1 oil which you can buy in 5 or 20L quantities - https://www.smithandallan.com/product/smit...e-oil-4127 2012 TDV8 Vogue (L322) |
