Home > Maintenance & Mods (L322) > Mannol Engine Oil Query
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
@JayGee ; please would you be able to expand a little more on the C1 cf C2 oil spec ? …..
I was watching Sam’s Motor & Machine on YouTube last evening where it was commented that “ C1 has now been replaced by C2 and then C3 “ I use Smith & Allen C1 but was wondering if I should seek out a C2 or C3 specked oil if C1 is old hat.
Here’s the video, the oil service is about 30 mins in. Note that Sam does talk though his oil spec choice considering his recent EGR/DPF delete.
https://youtu.be/S-SWu5i4adk?si=hkqUl3AsbaoY22A5 TDV8 4.4 2012
Post #686951 2nd Mar 2024 12:00pm
JayGee
C1 is low saps (addatives that form ash that can't be removed during the regan process and are ultimatley responsible for how long a DPF can work before it's soot capacity or flow capacity are compromised) for DPF equiped cars. Sam no longer has a DPF so can use any oil of the correct viscosity or a different viscosity as he has chosen. While technicaly you shouldn't use C2 or 3 the difference between low SAPS and mid SAPS on the remaining life of your DPF ( and car) is arguable. 2012 TDV8 Vogue (L322)
Post #686954 2nd Mar 2024 12:31pm
garyRR
Mannol oil is great oil - I use it for my business, but unfortunately they don't make a C1 specification oil. The main reseller of Mannol in the UK are Carousel.
For the 4.4 TDV8, it's 5W-30 C1.
Smith & Allan 5W-30 F is C1 specification. Petronas 5000 FJ is also C1 specification and has the correct 5005 approval, my personal preference. From Opie, it's about the same price as the Smith & Allan at the moment. 2015 Range Rover Autobiography 4.4 SDV8
Post #686980 2nd Mar 2024 6:17pm
pcourtney
Millers for me
https://www.opieoils.co.uk/p-60261-millers...WQQAvD_BwE
Millers Oils XF Premium C1 5W30 Fully Synthetic Engine Oil
XF Premium C1 is a fully synthetic, low SAPS oil for use in petrol, diesel and hybrid engines. Formulated for OEM vehicles which require a C1 5w30 viscosity, predominantly Land Rover / Range Rover vehicles fitted with Diesel particulate filters (DPF's).
XF premium C1 5w30 engine oil from Millers Oils is formulated with Dynamic Fluid Technology (DFT). This technology improves engine protection on cold starts and provides superior protection at high temperatures. It is also effective at reducing fuel consumption and lowering emissions.
Excellent cold start protection for engines
Superior protection at high temperatures
Can reduce fuel consumption and lower emissions
Suitable for use in modern vehicles including hybrids
Millers Oils XF premium C1 engine oil utilises the latest low SAPS technology to deliver ultimate soot control which helps protect after treatment systems such as Particulate Filters (DPF's), Selective Catalytic Reduction (SCR) and AdBlue. It is compatible with Petrol, Diesel and Bio-fuels and provides superior protection against sludge and deposits, keeping your engine cleaner and more efficient.
Specifications: ACEA C1
Approvals: Ford WSS-M2C934-B, Jaguar Land Rover STJLR.03.5005
Post #686989 2nd Mar 2024 6:59pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
I think that Mannol is a very under rated oil
This is what I use in my TD6 after contacting Mannol HQ for advice.
https://www.ebay.co.uk/itm/303941075870?ep...BMrr2krMBj
Jim
Post #687017 3rd Mar 2024 6:26am
supershuttle
This series of posts got my attention so I spent a few minutes googling and it seems that ACEA C1 is now an obsolete reference so I guess that in time it will disappear, what then should I put in my Range Rover . Geoff
Post #687020 3rd Mar 2024 9:00am
knwatkins
They certainly do - Mannol 7723. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #687021 3rd Mar 2024 9:10am
garyRR
Looks like it's £100 per litre in the UK. 2015 Range Rover Autobiography 4.4 SDV8
Post #687022 3rd Mar 2024 9:12am
knwatkins
That's not actually true. C1 has not been superseded by C2 and C3. They are different specifications. C1 has simply been dropped as a managed specification by the ACEA. It has not been replaced or superseded by another specification. Kev
Post #687023 3rd Mar 2024 9:13am
knwatkins
I haven't looked at prices recently as I've been using S&A but I bought 20 litres of it for £46.49 back in 2021. Kev
Post #687024 3rd Mar 2024 9:16am
knwatkins
I wouldn't worry Geoff, manufacturers will continue to produce oil to the same specification. They may not be permitted to label them as 'ACEA C1' but they may be able to label them as 'equivalent to ACEA C1'. Kev
Post #687025 3rd Mar 2024 9:18am
