Home > Maintenance & Mods (L322) > Mannol Engine Oil Query
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Hi all,
Whilst gathering parts for this year's service, I found 10 litres of Mannol 5W-30 for 48EUR delivered. Per the picture below, it states specifically for Jaguar/Land Rover STJLR.03.5005 - WSS-M2C934-A A/B, code number ´7909´
7909 arrived, but the label is different:
no mention of Ford or JLR specificity. But the code is the same, plus the viscosity. ACEA & API numbers match to.
I will probably send it back, not prepared to wing-it. But what would others do?
I have contacted Mannol to see what the differences are, no answer yet. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #681307 28th Dec 2023 11:53am
JayGee
Needs to be ACEA C1 (Low Ash) / WSS-M2C934-B 2012 TDV8 Vogue (L322)
Post #681311 28th Dec 2023 12:31pm
TDV8_Tommy
ok, cool - I´ll stick that in the next two oil changes for the MX-5 then.
On order now, 2 x 5 ltr spec C1 Jaguar/Land Rover STJLR.03.5005 - WSS-M2C934B.
47 EUR delivered, which is good.
I hadn't realised only Ford used C1 and probably hence why C1 was withdrawn by ACEA, now obsolete.
I´d be curious to know if anyone is using C2 on the 4.4 TDV8. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #681322 28th Dec 2023 1:59pm
John-suusex
https://www.ebay.co.uk/itm/304685626380?mk...media=COPY
this is what i have been using in my two. Did check with them and it's what they came back with.. 2008 TDv8 Vogue in Java black x2
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #681331 28th Dec 2023 3:21pm
General
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
I always use Smith & Allan
https://www.ebay.co.uk/itm/254938667441
Post #681332 28th Dec 2023 3:33pm
JayGee
John-suusex wrote:
https://www.ebay.co.uk/itm/304685626380?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=UtC3VvnORl6&sssrc=2047675&ssuid=kq0hfMU_QgC&widget_ver=artemis&media=COPY
That's fine as your 2008 doesn't have a DPF so any good quality 5w-30 will do the job 2012 TDV8 Vogue (L322)
Post #681339 28th Dec 2023 4:43pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Likewise. 20K miles on S&A so far. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #681344 28th Dec 2023 5:40pm
JayGee
Not 20k miles since the last oil change I hope 2012 TDV8 Vogue (L322)
Post #681357 28th Dec 2023 7:45pm
Danb_220_2019
Is that what I said?
Nope. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Post #681412 29th Dec 2023 4:07pm
JayGee
Sorry for suggesting it and not putting a Smile in it. 2012 TDV8 Vogue (L322)
Post #681429 29th Dec 2023 7:10pm
RiverBlanche
Hi,
I have used Mannol and Smith & Allan products for a number of years and been happy with both,
wait to see what they reply then decide Question see if they state it still meets the WSS spec
Post #681430 29th Dec 2023 7:12pm
3disco
Re: Mannol Engine Oil Query
TDV8_Tommy wrote:
Hi all,
I have done exactly the same and have been told it’s an old photo of a barrel and that it needs the c1so I guess that’s another barrel going back!
Post #682331 10th Jan 2024 2:26pm
TDV8_Tommy
Yes!
This was their email response:
"Thank you for your enquiry, I will be happy to help you.
It is possible that the Amazon dealer has not updated the images. The oils lose their approval after some time. Because the retailer has not updated the images, you have seen the old container, which still had the approval. However, the new container you received no longer has the approval, which is why you should not use it."
.... 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #682334 10th Jan 2024 2:30pm
IndividualM5
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
Surely, it’s the same oil!
I too am looking for the correct ‘reasonably priced’ oil to use in my 2017 4.4sdv8 and Mannol seems to fit the bill. Surely, it’s the same oil even though the label no longer has the STJLR.03.5005 quoted on it? I’m actually erring towards the 7908 Energy Premium, which is less than £60 for 20 litres. I’ve checked JLR recommended lubricants and they do say that any ACEA C2 oil may be used if STJLR.03.5005 is not available 🤔
Post #686945 2nd Mar 2024 10:19am
JayGee
AFAIK the manual says you can top up with C2 in an emergency but it doesn't say you can use it for an oil change. C2 is mid SAPS C1 is Low SAPS - if you have a DPF you should not be using anything but low SAPS. Smith & Allan do reasonably priced 5w-30 C1 oil which you can buy in 5 or 20L quantities - https://www.smithandallan.com/product/smit...e-oil-4127 2012 TDV8 Vogue (L322)
Post #686950 2nd Mar 2024 10:41am
