![]() | Home > Technical (L322) > Gear box Fault ZF8 speed |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
So an update
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Wow, very unusual to hear of a 4.4tdv8 diff going awol. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Hi mate
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 472 ![]() ![]() ![]() |
Hi Shaun, you don’t need to take the subframe down, the diff will wiggle out through the side once the drive shafts and prop are removed, its s a tight fit and is heavy so watch your fingers as it comes out, Not the easiest of jobs but is doable at home. |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 ![]() ![]() ![]() |
Have you checked the front driveshafts? If one has popped out slightly, you will lose all drive. The right hand one is prone to doing this especially if there has been work done on the driveshaft in the past and the C clip not replaced. |
Funny you should say that GT40
I wonder why they closed down. Too many disappointed customers perhaps?
Hi mate
