Home > Technical (L322) > Headlight Washer Fuse
Range Rover L322
Can anyone point me in the direction of the headlight washer fuse? 2012 L322 TDV8
Or shed any light on which fuse it is?
 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #680527 17th Dec 2023 11:26am
JayGee
Headlight washers not working? Likley as not the high pressure pump on the screen wash tank has failed. Easy job to change by unfastening part of the NS wheel arch liner. 2012 TDV8 Vogue (L322)
Post #680543 17th Dec 2023 3:49pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
Jaygee, recently I noticed that my headlight washer was not working. I also noticed the rear screen washer wasn't working. Do you know if its the same pump for these too? Presumably the main screen washer uses a different pump as it is still working. I have topped up fluid levels and checking light washers with lights on and I know it only functions every 4 or 5 times when you wash the windows.
Is there a separate loom that powers this pump?
Thanks in advance.
Post #695708 7th Jul 2024 5:29pm
Baltic Blue
It’s covered in detail in the 2010-12 workshop manual.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #695711 7th Jul 2024 5:52pm
Proftinkerpot
Thanks for this Baltic blue.
Post #695779 8th Jul 2024 6:57pm
pcourtney
Baltic Blue - could you possibly post the PDF again but larger, I cannot read the type when I enlarge the photo, thx
Post #697937 12th Aug 2024 10:09pm
Baltic Blue
The screenshot is really just to show you that it’s covered in the WM, which you can download from the Wiki., the whole PDF is several A4 pages long.
It’s in the Body & paint section .
Post #697950 13th Aug 2024 7:20am
