Home > Technical (L322) > Headlight Washer Fuse |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
Headlight washers not working? Likley as not the high pressure pump on the screen wash tank has failed. Easy job to change by unfastening part of the NS wheel arch liner. 2012 TDV8 Vogue (L322) |
17th Dec 2023 3:49pm |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 180 |
Jaygee, recently I noticed that my headlight washer was not working. I also noticed the rear screen washer wasn't working. Do you know if its the same pump for these too? Presumably the main screen washer uses a different pump as it is still working. I have topped up fluid levels and checking light washers with lights on and I know it only functions every 4 or 5 times when you wash the windows.
7th Jul 2024 5:29pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
It’s covered in detail in the 2010-12 workshop manual.
7th Jul 2024 5:52pm |
Thanks for this Baltic blue. |
8th Jul 2024 6:57pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
Baltic Blue - could you possibly post the PDF again but larger, I cannot read the type when I enlarge the photo, thx |
12th Aug 2024 10:09pm |
The screenshot is really just to show you that it’s covered in the WM, which you can download from the Wiki., the whole PDF is several A4 pages long.
13th Aug 2024 7:20am |
