Home > Technical (L405) > All I want for Christmas..... is a new Engine |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 231 |
So finally got around to looking at my poorly engine. Decided to pull it and see what damage has been done, hopefully as it was still running and the knock sounded like a big end as opposed to a main bearing it maybe salvageable.
18th Jan 2024 11:12am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1192 |
Watching with bated breath, Please keep us updated. 2017 SDV8 4.4 silicon silver AB
18th Jan 2024 11:42am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1379 |
For the reason that Craig mentioned earlier, I’d strip and clean it and put it back together to have peace of mind of no bits of metal lying about.
18th Jan 2024 4:42pm |
If I get a bit of time tomorrow, I'm going to pull the crank out, inlet manifolds, cams & followers etc. and give it a good wash through in the cleaner and see what it looks like. Ultimately if I need to take the heads off to be happy that's what I'll do.
18th Jan 2024 5:49pm |
Sounds like a plan. Good luck . V8 or else ... |
18th Jan 2024 7:39pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2501 |
You might want to see if bearing sets are available with 1 side notched to then have the caps notched. I understand they're available for the TDV6. |
18th Jan 2024 10:01pm |
That's a good idea, the ones I've managed to find so far are however as per standard design. I'll keep looking L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
18th Jan 2024 10:15pm |
So, it's been a while.... some good and some bad news!
24th Feb 2024 4:51pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1416 |
Wow, hat off to you sir, looking good. |
24th Feb 2024 8:25pm |
Thanks DrF, I'm kinda enjoying the project, not so much the wallet drain however! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
24th Feb 2024 8:33pm |
Just in case any unfortunate person ever treads this path again, here's a list of parts I've replaced, all as per Topix assembly guidlines. I'm sure some parts could be skipped, but I'm going by the book and hoping for a problem free future!
24th Feb 2024 8:50pm |
Have you considered fitting a sensor for an oil pressure gauge whilst easily fitted, even if you wouldn't normally have a gauge fitted?
25th Feb 2024 12:47am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 334 |
Well done 4RRS 👏🏻 great work and thread 👍 |
25th Feb 2024 6:27am |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 179 |
Brilliant thread,
25th Feb 2024 10:58am |
