Home > Technical (L322) > Knocking noise HELP!
E18RLY
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I've had a few problems with my 52 l322 hse but after weeks in a garage getting compressor and few other little things I've still got a knocking noise on the driverside front wheel somewhere when a go over speed bump or put hole the garage that have changed air susp compressor ( garage I bought it from fixing it under 3 month guarantee they give ) have said there's no play on any bush rubber or anything they don't no what it is. The noise seems to be getting worse and with a baby in the car I want it fixed please help !! The garage are not a land rover specialist just a little garage with mechanics
Post #73863 26th Jul 2011 8:20pm
allycraven
Just had the drop links changed on mine after suffering exactly the same knocking sound from drivers side front and it sorted the issue for me.
Post #73865 26th Jul 2011 8:39pm
E18RLY
Surely a garage should find that tho is there not a hidden bush on suspension ? I'm gonna get the jack out at the weekend hopefully it's gonna be something like that lol
Post #73866 26th Jul 2011 8:49pm
Balljoints, trackrod ends, drop links, there are plenty parts that can cause a knock.
Post #73867 26th Jul 2011 8:51pm
allycraven
Drop links don;t always show signs of obvious wear and will take quite a bit of force when jacked up to see if there's any play. Maybe they just didn't use a long enough cheater bar!!!
Just about the cheapest bit to start changing anyway - unless you go to a Stealer that is!!
Post #73868 26th Jul 2011 8:56pm
E18RLY
Hopfully al find something so there's nothing hidden Anywere that it could be causing it? Just usual kinda things
Post #73879 26th Jul 2011 9:33pm
marbleweazel
United States 2005 Range Rover HSE 4.4 V8 Java Black
I had a knock when i first got my rover it was the sway bar mounts, come to think of it i think they replaced the whole thing while it was unnder warrenty
Post #73888 27th Jul 2011 3:57am
stevenA
2002 Range Rover Vogue Td6 Zermatt Silver
I found that the problem with mine was the compliance bushing!
I had no knock until I had the diff mod done by the stealer - they release this to do the mod.
After getting it back, the next time I hit a bump I had a knock. I looked underneath and found two things. Although they had replaced the bolt as part of the diff mod, they had not torqued it up fully, and the little torque they had put, was done with the car in the air, wheras the procedure clearly states that it must be finally torqued with the full weight on the wheels. Unfortunately, this requires a pit or similar, as it is hard to get the required torque with the weight on the wheels because of the angle and limited clearance.
You can easily see if this is the problem by looking at the bushing and where it hits (you will see a mark on the rubber) - it should hit straight in the middle of the flat face, but if torqued up with the wheels in the air, it will hit at the top (and hence knock).
Easy fix is to slack off the bolt with the weight on the wheels and suspension in highest position, and it will suddenly snap into the right (or nearly right) position (if not, a quick application of the famous LR special tool will help it Wink ). Then torque it up - 190Nm from memory!
Hope that helps
Post #73967 27th Jul 2011 9:32pm
E18RLY
never accually been under the rr yet so not really sure what im lookin for with that one lol ive done everything on old cars from brakes changes to engine swaps on clio sports, civics ect but im a bit weary about getting my hands dirty with this lol thanks for the advice tho ill hopefully relise what you mean once im under it
Post #74310 31st Jul 2011 7:30am
bob.lydon
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
As previously suggested change the drop links, easy enough job to do, did mine as i was having exactly the same problem, would change them both as they are not to expensive.
bob
Post #74440 1st Aug 2011 7:20pm
bob.lydon
bob
Post #74441 1st Aug 2011 7:21pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
change your droplinks 2004 black Vogue TD6
Post #74473 1st Aug 2011 10:21pm
