![]() | Home > Technical (L322) > Knocking noise HELP! |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
Just had the drop links changed on mine after suffering exactly the same knocking sound from drivers side front and it sorted the issue for me. |
E18RLY Member Since: 02 Jun 2011 Location: sout shields Posts: 29 ![]() ![]() ![]() |
Surely a garage should find that tho is there not a hidden bush on suspension ? I'm gonna get the jack out at the weekend hopefully it's gonna be something like that lol |
Balljoints, trackrod ends, drop links, there are plenty parts that can cause a knock. |
Drop links don;t always show signs of obvious wear and will take quite a bit of force when jacked up to see if there's any play. Maybe they just didn't use a long enough cheater bar!!!
Hopfully al find something so there's nothing hidden Anywere that it could be causing it? Just usual kinda things |
marbleweazel Member Since: 20 Jul 2011 Location: Sacramento, CA Posts: 13 ![]() ![]() ![]() |
I had a knock when i first got my rover it was the sway bar mounts, come to think of it i think they replaced the whole thing while it was unnder warrenty |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 ![]() ![]() |
I found that the problem with mine was the compliance bushing!
never accually been under the rr yet so not really sure what im lookin for with that one lol ive done everything on old cars from brakes changes to engine swaps on clio sports, civics ect but im a bit weary about getting my hands dirty with this lol thanks for the advice tho ill hopefully relise what you mean once im under it |
bob.lydon Member Since: 25 Apr 2011 Location: wallsend Posts: 36 ![]() ![]() ![]() |
As previously suggested change the drop links, easy enough job to do, did mine as i was having exactly the same problem, would change them both as they are not to expensive.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
change your droplinks 2004 black Vogue TD6 |
