Home > In Car Electronics (L322) > TV in motion |
rwilson Member Since: 17 Jan 2011 Location: London Posts: 84 |
I have being trying to fit a plug and play TV in motion to my 2009 Vogue. After leaving the ignition off for about 10 mins I fitted it. I then turned on the TV which worked, but message came up with suspension fault on the dash. The TV does not work in drive as it now should (sound only, as the manufacturer intended). When I removed the unit the fault message disappears and everything returns to normal
26th Jul 2011 6:01pm |
yes 3 DIP switches all in the up position as instructed. To be fair supplier has offered a refund but thought I would ask here first before sending it back.
26th Jul 2011 6:25pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
have you tried all the different combinations of the switches?
26th Jul 2011 6:43pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Hi Richard, can you post a link where you bought the TV in motion box from? The 753 hack is getting a bit tedious now.
26th Jul 2011 6:57pm |
Says it was for Disco 3, Sport and Vogue. I asked to make sure that Vogue meant 2009 not older style 2005 type. I haven't tried changing the switches as the guy said that they should be all up.
26th Jul 2011 7:24pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3749 |
Justin, what is the 753 Hack? I know about the 1791 but have never heard of the 753?? |
26th Jul 2011 8:59pm |
It enables TV on the move http://www.fullfatrr.com/forum/topic2243.html Gone - Range Rover Supercharged 2006 |
26th Jul 2011 9:03pm |
ah thanks muchly |
26th Jul 2011 9:16pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
this is a question for those of you who have had a look at the back of the head unit. does the touch screen (MOST) headunit have a 17 pin connector or a quadlock?
30th Jul 2011 7:07am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
heres a pic of the back of the screen joe..
30th Jul 2011 9:05am |
thanks for the pic.. Current: TDV8 (3.6) RRS HSE
30th Jul 2011 12:57pm |
couls someone with a (MOST) touch screen systen, please let me know how to remove the head unit to connect my new VIM unit?? Current: TDV8 (3.6) RRS HSE
2nd Aug 2011 7:37pm |
just a quick bump for my last post.
6th Aug 2011 1:48pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
For the pre-interior-facelift models, go to youtube and search powerfulUK's vids for the video on installing the aftermarket nav. It shows exactly how to get to the head unit.
6th Aug 2011 8:52pm |
