Home > Technical (L405) > Plugging in Mongoose JLR gives instant error codes
FleXzoR
Belgium 2016 Range Rover Autobiography SDV8 Santorini Black
Hello over here,
I recently acquired a new (to me) L405 4.4sdv8 LWB AB.
I had the JLR Mongoose cable left from my previous L322 supercharged.
When plugging in this cable, without even being connected to my laptop (visa-versa is the same), my car starts throwing all possible faults. (numerous amount)
When ignoring these faults, i can continue working and even change the CCF.
Any ideas why my vehicle instantly throws all errors when plugging-in the OBD JLR mongoose socket?
Thanks MY2008 Buckingham Blue Supercharged - gone
MY2016 Santorini Black 4.4 SDV8 LWB AB
Post #674804 3rd Oct 2023 8:15am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
You need to remove pin 13 from the mongoose connector as it is not implemented on earlier vehicles but 2013 on it causes a short on the MS Can and hence you get lots of warning lights and errors until you unplug it and leave the car to shutdown.
You'll probably find your Mongoose isn't a genuine item, if so be careful if re-flashing any modules and make sure you have a battery support unit connected.
Hope this helps! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #674816 3rd Oct 2023 2:33pm
FleXzoR
Thank you for your prompt reply!
I will try and report back but i assume your answer will be spot on.
Thanks! MY2008 Buckingham Blue Supercharged - gone
Post #674822 3rd Oct 2023 3:00pm
FleXzoR
Works like a charm! Thank you! MY2008 Buckingham Blue Supercharged - gone
Post #674827 3rd Oct 2023 5:10pm
4RRS
Thumbs Up L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #674829 3rd Oct 2023 6:16pm
fisha
I wish I’d known this … I’d spent ages trying to get it working and had the above issue … I’ll maybe try again. V8 or else ...
Post #674840 3rd Oct 2023 10:55pm
4RRS
And me, my solution was to buy the genuine JLR VCI, then I discovered the pin 13 solution, worked perfectly, but just use the JLR unit now as most Mongooses are clones and *can* screw up when flashing ecu's.
Every day is a learning day!! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #674841 3rd Oct 2023 11:00pm
