Home > Technical (L405) > Plugging in Mongoose JLR gives instant error codes |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 194 |
You need to remove pin 13 from the mongoose connector as it is not implemented on earlier vehicles but 2013 on it causes a short on the MS Can and hence you get lots of warning lights and errors until you unplug it and leave the car to shutdown.
3rd Oct 2023 1:33pm |
FleXzoR Member Since: 28 Jan 2013 Location: Bruges Posts: 44 |
Thank you for your prompt reply!
3rd Oct 2023 2:00pm |
Works like a charm! Thank you! MY2008 Buckingham Blue Supercharged - gone
3rd Oct 2023 4:10pm |
L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
3rd Oct 2023 5:16pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I wish I’d known this … I’d spent ages trying to get it working and had the above issue … I’ll maybe try again. V8 or else ... |
3rd Oct 2023 9:55pm |
And me, my solution was to buy the genuine JLR VCI, then I discovered the pin 13 solution, worked perfectly, but just use the JLR unit now as most Mongooses are clones and *can* screw up when flashing ecu's.
3rd Oct 2023 10:00pm |
