Home > Maintenance & Mods (L405) > which oil |
With a DPF it needs to be C1 specification - I used Millers Oils Trident Professional C1 5w-30 Fully Synthetic Engine Oil as Castrol wasn't available at the time in the correct spec. You don't need to reset via the OBD port, have a look in the WSM (link in the Wiki) for details of how to read & reset the oil level & service interval reset |
1st Oct 2023 11:18am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1145 |
Myself and I think Kot use this.
1st Oct 2023 11:27am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1230 |
Yep C1 it is, and PETRONAS is good enough for Lewis Hamilton and co.
1st Oct 2023 12:48pm |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 189 |
600 miles and needs another oil change. Thats mad even by ffrr standards. I’d be doing mine once every two or three weeks at that rate 2016 4.4 diesel |
1st Oct 2023 3:12pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3824 |
I don't mean to hi jack the thread but I have some some oil left over from changes I have done (I always get 10L but my Range Rover takes less), some Smith and Allan some Castrol and I was thinking of the offer from Opie for next time(Petronas).Can it be safely mixed if it's all C1 5-30W and fully synthetic. Or should I stop hoarding and take it to the tip, Geoff |
1st Oct 2023 4:10pm |
It depends how long it takes the OP to do 600 miles... |
1st Oct 2023 6:14pm |
If it's all the same viscosity, specification & composition, then it'll be fine. |
1st Oct 2023 6:15pm |
I think judging by the reaction of the op seems surprised also 2016 4.4 diesel |
1st Oct 2023 6:54pm |
V8Russ Member Since: 22 Jul 2023 Location: Yateley Posts: 29 |
I did 700 miles in under 4 weeks of driving. Its strange I was hammering it a bit to see if it made any difference, and it did, the mileage service interval went up. Soon as i hit motorway speeds for an 1/2 hr to an 1hr it reduces. Anyway I did my first RR oil change today. Very easy with the vacuum pump. Costs were, oil £120, filter £8. torque wrench £40, 36mm socket £16. |
1st Oct 2023 7:00pm |
Then there is a concern, either the oil level is not reading correctly, there is a sensor issue with the DPF regen or the last oil change was not reset correctly. Use this oil change as a baseline and monitor the service interval countdown. would also be helpful to do a full vehicle DTC read, if you have the capability. |
1st Oct 2023 7:19pm |
DTC? |
1st Oct 2023 7:21pm |
Diagnostic Trouble Code - 'fault code'. |
1st Oct 2023 7:22pm |
Reset saying 16030 miles until service, so will keep an eye on it. |
Ill need to buy a code reader but I believe they're around £500-600. |
1st Oct 2023 7:23pm |
